95 1500 4x4 tyranny fluid leaking truck won't move.
Old Feb 27, 2014 | 8:53 AM
jbaesl's Avatar
Default 95 1500 4x4 tyranny fluid leaking truck won't move.
Girlfriend was driving it and the truck stop moving when pressing gas. Said tranny fluid was leaking everywhere. What could be the problem?
Old Feb 27, 2014 | 8:55 AM
'03 Heavy Chevy's Avatar
I'm guessing she ran over something and banged up the transmission.
We need more details.
Old Feb 27, 2014 | 8:57 AM
Pugly's Avatar
I would have to think the leak is the problem.
Old Feb 27, 2014 | 9:05 AM
jbaesl's Avatar
What kind of details? Yeah but I can't figure out where it is leaking from.
Old Feb 27, 2014 | 9:10 AM
jbaesl's Avatar
Looked under hood. A line coming from radiator is broke but I don't where it was going into. Is there a way u can post a picture? Brand new to this forum
Old Feb 27, 2014 | 9:14 AM
LOL - I was thinking maybe the gf shouldnt be driving his truck anymore.....
You might have to crawl under her (the truck, not your gf) and find if its leaking from the front, side, back of the transmission. Does it look like it has hit something? Is the transmission pan missing? Bolts loose? Etc........
Old Feb 27, 2014 | 9:18 AM
http://www.justanswer.com/uploads/St..._130218_a1.gif
Like this one?
Old Feb 27, 2014 | 9:28 AM
Pugly's Avatar
It could be a leak in the pan, cooler lines or the cooler itself.
You might have to add more trans fluid - have you checked the fluid level in the trans?? It appears from your post that there is not enough left in the trans to leak out. I'd add at least 1 gallon of the appropriate ATF fluid. Block all 4 wheels, put the transmission in park, set the parking brake and put the transfer case in neutral to ensure that the truck will not move with the engine running.
Wearing proper eye protection open the hood and start the engine - inspect the cooler lines, connections and cooler for leaking fluid. If none are detected climb under vehicle and inspect the trans pan and cooler lines and connections.
Old Feb 27, 2014 | 9:38 AM
Looks like we lost him Pugly.......
Old Feb 27, 2014 | 9:41 AM
Pugly's Avatar
I was only trying to help.
