95 C1500 5.7L hard start warm
Old Jul 6, 2011 | 6:09 PM
Shrike83's Avatar
Default 95 C1500 5.7L hard start warm
Ok, really funny issue here. It's hard to start after it sits out in the hot weather for a while. I can generally drive it after it's running, turn it off and then start it, so long as it doesn't sit 5 minutes. It starts fine in the morning or late in the evening, but if it's been sitting in the sun, it cranks fine, but won't catch. Runs fine otherwise. Changed coolant temperature sensor ontop of the intake manifold. No go. Any ideas?
Old Jul 7, 2011 | 7:53 AM
shamrock246's Avatar
is the fuel pressure bleeding off, do you have spark when it wont start,if you cycle the key a couple of tmes when hot then try to start will it start?being a TBI you could pull off the air cleaner and see if it injecting fuel
Sean
97 4x4 burb
Old Jul 7, 2011 | 9:34 PM
Shrike83's Avatar
Won't be able to check for this reason, but when it gives me a lot of trouble.. By the time it does start, I have to rev it or it'll quit. Like it's starting to flood. Turning the key to aux and off repeatedly before trying doesn't seem to make a difference. I can hear the pump prime.
Old Jul 7, 2011 | 10:12 PM
Chuzz's Avatar
Faulty ignition control module? You can remove it and have it tested at Autozone or Advance Auto Parts.
Old Jul 8, 2011 | 12:07 AM
Shrike83's Avatar
Something else to try saturday when I'm off. Plugs, distributor, rotor are all pretty new. Ran fine till this hot weather hit.
midnightrumbler
Jun 27, 2010 3:47 PM
isrblue
Jun 14, 2010 7:36 AM
jgore43
Mar 4, 2010 5:06 PM
aman721
Feb 3, 2008 4:12 AM
