95 Sierra: 4x4 shift linkage adjustment
Old Sep 30, 2012 | 11:30 PM
98Silverado1500's Avatar
Default 95 Sierra: 4x4 shift linkage adjustment
95 Sierra that will go into everything but 4H, the 4x4 shift lever isn't lined up perfectly with 2H when its in 2H, its offset.
Does this adjustment need to happen at the shift lever or the linkage underneath the truck?
If it is the linkage underneath the truck how to you remove the white/yellow bushing's at each end of the linkage rod?
The truck has a body lift, is this creating a problem?
Does the truck actually need to be off the ground to adjust the linkage? (Does the load of the vehicle effect the tension on the linkage?
Thank you for your time.
domano 68
Jan 23, 2014 7:20 PM
lentesubigo
May 26, 2012 4:14 PM
phord
Jul 14, 2011 7:35 PM
Nightman
Mar 11, 2010 4:27 PM
unsnook123
Jan 1, 2010 8:32 PM
