96 Chevy 5.7 wont start, no spark, everything new! lol
1996 c3500 No Spark, Wont Start chevy pickup 5.7 350 motor 4x2 4l80 Trans 266K Miles
Was running very rough but not stalling, gradually got worse and would begin to have problems accelerating and surge when you apply gas at times. I changed cap/rotor/plugs/fuel filter and it ran a lot stronger but still with a miss and surge. I changed all 4 oxygen sensors with AC Delco Parts. Started right up ran smooth, I hit the gas a couple times and it sounded worse than ever, then stalled. I started it again with difficulty and it did not run right but would barely idle, after about a min it cut out and wouldnt restart. It would crank over then sound like it was kicking back that created a nasty grinding sound...sounded like the flywheel/starter etc...I think the battery was a bit low at the time too. Due to the mileage I put a new Crankshaft Pos Sensor, Ignition Coil, and now ignition Module, and igntion hall sensor(pick up coil). No check engine light or codes. Te Dist. is spinning while starting. Whats left besides the PCM? Maybe im overlooking something? Any help would be appreciated. Michael
Did you check timing gears and timing chain? With over 200k on the clock, I would look there next.
Good Luck!
Good Luck!
Food you ever figure out what the problem was? I have the same issues
New User
Awaiting E-mail Confirmation
streetterrorist
13
April 15th, 2022 1:42 PM
jim_raynor610
April 3rd, 2022 4:16 PM
Scootertrash
14
July 26th, 2009 10:32 PM
