97 5.7l Silverado Starting problems
Old May 27, 2011 | 4:53 PM
jworrall63's Avatar
Angry 97 5.7l Silverado Starting problems
Hi all, i'm new to the site so thanks for any help I get. I am having issues with my 97 5.7l 4x4 Silverado. Some times it starts perfect and runs great. Other times it wont turn over unless I really stomp on the gas pedal, then it idals very rough for a min or 2. Then it seems to dial its self in and run great. During those 2 min, if I try to put it in gear it dies.
I tested the fuel pressure and it was low and bleeding off fast when shut off. So I put in a new fuel pump and filter. Now it has great pressure and stays pressurized when shut off. But it did not fix the problem. I'm at a loss.
I put new air and oil filters. oil change. No trouble lights lit up. There was one originally and it was the eng-1 fuse kept blowing. I found a pinched wire to the camshaft position sensor and re wired it. When I had a new tranny put in it they pinched it. fuse doesn't blow now and no trouble lights.
Any ideas? Could that sensor be bad now?
It only seems to give me trouble after it has recently ran. If it set for a day, it will start right up no problem.
Thanks
Old May 29, 2011 | 9:42 AM
OLD WRENCH's Avatar
Could have some leaking fuel injecters flooding the engine.
Old May 30, 2011 | 7:33 AM
shamrock246's Avatar
Ditto OLD WRENCH,the fuel pressure regulator could be leaking,if you have the old poppet style injector spider i would ditch it and get the upgraded one found it on amozon for about $215
Sean
97 4x4 burb
maradison
Jul 29, 2021 9:27 PM
hardy7302
Feb 10, 2015 2:58 PM
bigj2201
Jan 19, 2012 9:56 PM
