98 c1500 a/c
Old Sep 6, 2012 | 4:01 PM
nrsanders's Avatar
Default 98 c1500 a/c
i have a 1998 c1500 305 with an a/c issue. i tried sealing the system and than recharge is with a/c pro, and it worked for a little while but it no longer works. the compressor clutch keeps kicking off and it wont hold a charge. im pretty sure i need to replace the compressor because all the wires are good no frayed ends or anything. if this doesnt fix the issue how do i fix the lines or replace them without having to take it to a shop (short on cash). thanks in advance
Old Sep 6, 2012 | 4:32 PM
Allan In NE's Avatar
The compressor cyling like that means you are low on freon again. You've got a leak somewhere (not to say that it isn't the compressor leaking).
Look for an oil track or have a shop diagnose it with a sniffer. Leaks are pretty easy to find tho. They always leave that oil track at the source.
Allan
Old Sep 6, 2012 | 4:41 PM
kevinkpk's Avatar
Allan
It needs to have the gauges put on it to verify if the freon is low. If it is, use dyed freon, that will help identify where the leak is.
DarkAsylum
Nov 20, 2006 11:05 AM
sp3edr4cer
May 9, 2006 4:13 PM
alex07
Mar 28, 2006 10:59 PM
dwmmatt23
Mar 18, 2006 5:34 PM
