98 C1500 - spot for second battery
Old Apr 9, 2014 | 3:56 PM
squierjosh's Avatar
Default 98 C1500 - spot for second battery
Hi, I'm pretty new to the Silverado world, so I'm sure I'll be posting plenty of newbie questions in the near future. First one: I see there's a spot for a second battery. Is this something an every day driver would need, or is it more for hauling trailers and other powered accessories?
Old Apr 9, 2014 | 4:14 PM
My 2013 also has a second battery tray. You do not need this for normal everyday driving.
Old Dec 2, 2014 | 11:07 PM
Roadhogg2004's Avatar
this has nothing to do with your truck. But, way back in the day, my Dad had a wrecking yard (JunkYard) when I was a kid. A man drove up, he had a 1957 Chrysler Imperial. It had a 392 Hemi in it. It had 2 generators and 2 batteries and I think 2- 4bbl carburetors. and I never send another one.
Old Dec 3, 2014 | 6:04 PM
JK23112's Avatar
The reason your truck has a place for a second battery is because of the diesel engine option for the Chevy & GMC HD series. The trucks equipped with the 6.2, 6.5 and 6.6 (Duramax) diesel engines all require two batteries instead of one. This is because of the glow plugs and high cold-cranking amperage required to wake up those engines on cold mornings.
It is easier for Chevy to make all trucks the same way and only install the second battery in the oil-burners.
Old Dec 24, 2022 | 8:28 PM
Bobertgmt400's Avatar
I know it's a bit late by many years but the second battery tray would be for the diesel model. Most diesels got 2 batterys. Although not necessary you can put in another battery great if your running alot of accessories or like a high powered sound system.
Old Dec 26, 2022 | 9:04 AM
dpieroni3's Avatar
Duel battery option was available on gassers also. On some had a isolation set up, I mostly see it on trucks with snow plows or nave a need for aux 12V power. Example: utility truck, Winches, Etc. Like the others have said, It's not necessary on all vehicles unless there is a need.
brunoboxer
Feb 21, 2014 8:05 PM
Athmer68
Sep 8, 2011 11:47 PM
Athmer68
Sep 8, 2011 6:30 PM
SabrToothSqrl
Oct 8, 2009 10:16 PM
Hardin Thicke
Jul 18, 2008 1:22 PM
