98 chevy oil pressure issue and fuel gauge
hello i just went and traded my 99 ford mustang for a 98 chevy 1500 with a 8in lift and 35tires 5.7L vortec. now my issue i was driving her home noticed the gas gauge was moving a little bit back and forth then when at idle it jumps all over the place and when it is off it sits at 3/4 tank and the oil pressure it will sit at about 40 when doing 55-60 then when i let off it will jump all the way past the last mark n back to 30-40 area but i dont feel any werid stuff from the truck. it might have a bad oil pan gasket. i am new to theise trucks and dont know very much about them so all help is apreishated thank you very much
doug
doug
in my 01 silverado 5.3 it does the same thing with the oil pressure and I've been told it's a bad sendin unit...as for the gas gauge new fuel pump will do the trick
well i just went out to go get some stuff from the store it wouldent crank over the starter would just wine or what ever u wana call it and the motor wouldent rock so i climbed under it and looked the bolts seemed fine n the wireing was good to so i calleds the guy and he said the started was to small when he got it and i have to just walk it back in to its spot well i cant do that n the starter gear isnt reaching the fly wheel all thw way just gets it enough to scrap it so i guess it walked it self off some how. any ideas on that im not to familer with starters as well since im 17 but i know the basic but are you sapost to beable to see the starter gear when no cranking?
Steelman512
June 8th, 2023 2:51 PM
not_a_car_dude
September 15th, 2013 7:41 PM
