98 k1500 misfire and smoke problems
Old Jul 29, 2012 | 7:35 PM
moose's Avatar
Default 98 k1500 misfire and smoke problems
i just bought a 98 chevy with a 5.7 in it. not much later it started to blow black smoke out of exhaust. cylinders 2,4,6,8 all had missfires also. swiched the O2 sensors around and the miss fire switched sides to the odds. So replaced O2 sensor and ran fine and no more codes popped up. about two days later light came back on and can see black smoke starting to come out of exhaust. the side that is bad has a catalytic converter that has a leak also. please help!!
Old Jul 30, 2012 | 4:26 PM
SweetEmotion's Avatar
try cutting out/replacing your cats.(magnaflow direct fit dual cats run about $360.)a good options. clean all O2 sensors. check and replace spark plugs with premium plugs. run it and see.
Old Jul 30, 2012 | 6:31 PM
moose's Avatar
thanks i will give that a try
buddyleno
Mar 31, 2017 8:13 AM
greesha
Jan 23, 2016 8:34 AM
Biggumzmcgee
Nov 15, 2009 10:51 AM
tfaber119
Sep 20, 2009 8:06 PM
