98 Z71 will not start
Hey guys I am new to the forum. About a week ago my truck started getting harder to start I mean you would have to turn it over 4 or 5 times to start it.This past Monday it wouldn't start at all it would try to but never did.I changed the fuel filter and I had tried to crank it so much the battery got a little weak.I boosted it off and it started right up. Drove it around town and thought my problem was fixed.Turned it off and cleaned my tools up and got in it to pick up my son and it was the same thing all over again.Tried to start it and it would try but wouldn't start.The battery started to get weak again and when we connected the booster cables it started right up.The same thing again yesterday would not crank without cables. Another thing that is going on that the truck drives and runs smooth until you get down on it then it wants to choke down and sputter but it clears up when let off on the accelerator.
Sounds like the fuel pump is letting the fuel in the line bleed back into the pump. Could be the check valve built into the fuel pump is bad. But since you also have a problem when getting on it hard, you should change the pump. Do a fuel pressure check also.
checked fuel pressure 60 -65 pounds ran diagnostics and showed cam and crank senors codes.changed cam sensor, crank sensor and rotary button in distrubutor.Still doing the same thing you can crank it with a boost and it idols fine and runs fine until you floor it and then it smothers and doesn't want run.frustrating.
attycda
December 27th, 2021 12:34 PM
Sparky Sparks
January 23rd, 2019 10:53 AM
Xerklite
April 27th, 2013 9:14 AM
Igotasilveradonstuff
December 8th, 2010 12:55 PM
