98'1500 4.3v6 to V8????
Old Nov 16, 2009 | 7:25 PM
Bill's Dad's Avatar
Default 98'1500 4.3v6 to V8????
Could I easily swap out the 4.3 and install a 350cu.in 1997 Vortec V-8? would need exhaust manifolds from v8 truck...would everything else simply be plug n play? would need to trim or replace radiator shroud and maybe replace prom?? TIA!
Old Nov 16, 2009 | 8:18 PM
MDTAHOE's Avatar
Professional Mechanic
My understanding is, the firewall must be relived some (beat in) for room. You need the computer and harness unless you go carbureted. You need special motor mounts (kit). A different radiator and fan. I sure other things also. I have never done it or seen it done. I have only heard people wishful thinking out loud. I bet if you google it you will find out everything you need to know.
Old Nov 16, 2009 | 8:23 PM
Bill's Dad's Avatar
sounds like a bit more than I want to get into at this time....Thanks for the info.
Old Nov 16, 2009 | 8:25 PM
MDTAHOE's Avatar
Is the truck a s-10 or a full size? If it is full size alot of above does not apply.
Old Nov 17, 2009 | 8:01 AM
Bill's Dad's Avatar
full size...c-1500.
Old Nov 17, 2009 | 8:47 PM
MDTAHOE's Avatar
Should go right in with only the harness and computer.
Chevrolet Forum News
Jul 15, 2014 4:48 PM
makingaZJ
Jun 27, 2011 11:25 PM
bayonnebandit
Oct 19, 2010 8:26 AM
