99 1500 z71 running lean
Old Mar 14, 2013 | 1:59 PM
KyN8's Avatar
New User
Awaiting E-mail Confirmation
Default 99 1500 z71 running lean
I have an occasional check engine light that comes on and my voltage will drop slightly and then go back up. Got Auto Zone to check it and said that the fuel is running lean. What are some possible causes? (Starting with the cheapest lol) I do have dual exaust if that matters.
Old Mar 14, 2013 | 2:58 PM
Fishinfooleric10@aol.com's Avatar
When you say running lean, did it give you a bank 1 or bank 2 code. I would start with fuel filter first.
Old Mar 14, 2013 | 8:42 PM
KyN8's Avatar
New User
I don't know what bank code. Thanks for the tip, will check that out
Old Mar 14, 2013 | 9:46 PM
bank means sides of motor, like bank 1 means I think the left side of motor is running lean. The reason I say this is because my 99 was running lean and luckily that was the first thing I went to and it ended up being fuel filter.
Old Mar 15, 2013 | 3:58 PM
KyN8's Avatar
New User
Ok. Makes sense. Thanks again.
Old Mar 16, 2013 | 10:53 AM
KyN8's Avatar
New User
I didnt realize it but I had a K&N air filter and the code was showing in bank 1&2. They said it was due to the K&N air filter because the grease off of the filter was coating the mass flow air sensor. They said if I switch back to a paper filter it would stop.
Old Mar 18, 2013 | 9:38 AM
I have never heard of that but it seems legit. It is worth a try.
saver40
Oct 17, 2014 7:52 PM
militarydave
Jan 29, 2012 5:44 AM
jus83
May 16, 2011 5:48 PM
skatermike21988
Mar 15, 2010 2:04 PM
mike85
Jun 16, 2009 5:21 PM
