99 4wd not engaging
Old Feb 19, 2008 | 9:25 AM
holyspatulaboy's Avatar
Default 99 4wd not engaging
i have a 99 chevy silverado ext cab 4wd....i belive something is wrong with the transfer case but dont know what....when i engage it into auto 4wd it works fine but when i put it into 4high or 4 low it stays into 2wd... you can hear the transfer case switching gears for both. but all that will spin is the rear wheels? as far as i know the front end is engaging cause when i put it in 4wd on the fly it pulls hard to the right. so i assume it is somehere in the transfer case it self.. if you could help me i woudl appreciate it. (it is the electric push button style)
Old Feb 19, 2008 | 9:35 AM
northey87's Avatar
Default RE: 99 4wd not engaging
Welcome to the forum!!! Someone here should be able to answer your question, hang in there.
Old Feb 19, 2008 | 12:40 PM
2000 zx3's Avatar
hi , i wouldnt asume anything yet , that button that engages the transfer case is prone to going bad , if you havent replaced it before you most likely will , have it checked out at the button , normaly when they do go bad they will default to 4 wheel drive only , but its electrical so anything could happen .
Old Feb 19, 2008 | 3:55 PM
ehhget's Avatar
Mine would not switch out of 2WD and it was a switch at the transfer case. Not sure exactly what it was since it was warrantied but my bet is it is electrical not mechanical.
Old Feb 20, 2008 | 5:26 PM
thanks i crawled under it... i had a buddy switch from 4h to 2h and you can hear a motor whine.. but i almost sounds like it is binding up... looks almost like a worm gear motor so imma try with that first and see what happens..
pacaguy
Jan 18, 2022 1:00 PM
logeelandzr2
Jan 12, 2016 8:17 AM
Suburban Rev
Feb 16, 2014 12:03 AM
BYUFanatic
Aug 2, 2008 1:30 PM
timdogg1313
Sep 9, 2006 7:01 PM
Top
Follow Us
