99 rodo z71
Old May 11, 2012 | 11:45 PM
Doug Roberts's Avatar
Default 99 rodo z71
How much play is in transfer case ?? I get a thud so jacked truck up rear end is OK . The play is from transfer case .the ujoints look good
How do I open and look at chain and if floppy what's needed
Old May 12, 2012 | 10:20 AM
cleveland63b's Avatar
grammar and detail would be helpful but there shouldnt be much play in the tcase itself, pull the plugs check the fluid and if you can see inside rock the driveshaft back and forth see if you have a floppy chain
also when is it clunking? I'm assuming when you're going into 4wd?
Old May 12, 2012 | 7:33 PM
Lol phone fixed it and was late ill fix it
Old May 12, 2012 | 7:39 PM
No clanking in 2w at a start like ujoints are bad but its in case I think its chain like u said
Old May 14, 2012 | 7:35 PM
So can I fix chain or is it just replace them
99ChevyZ71
14
Aug 29, 2012 8:22 AM
jgray152
Feb 19, 2012 11:12 AM
