99 Silverado stuck in 4 lo
Old May 18, 2012 | 10:28 PM
shlbsnake's Avatar
Default 99 Silverado stuck in 4 lo
Hello, I am working on a freinds 99 silverado with a 5.3 in it. He said the service 4wd light would come on and so I told him I would look at it for him. The light was not on and the 4wd worked perfectly. I drove it home and the message came on so I stopped and put it in 4hi and there it stuck. I then got it stuck in 4 lo and it would not come out. Everytime I cycle the igniton the motor actuates but it is still in lo. I finally got it into 2wd but as soon as I cycled the key it went back into 4lo. After awhile it is now back in 2wd and I unplugged the motor.When the key is turned on the 4low light flashes then all the lights go out and I can't do anything. I can't find a connector pinout but my readings are as follows with truck running- 6 pin connector: 4 pins have 5v, 1 has 8v and one ground. The 4 pin connector 1 has 12v 2 have 5v and the other has 0 and is not a ground? I have read about the encoder, the motor and the switch all being common problems. Any Ideas?? sorry for the long read and thanks,
Tony
BigblackHo3
Apr 5, 2013 8:54 AM
EagleEye82
Feb 21, 2012 3:02 PM
93silverado
14
May 6, 2009 9:03 PM
bdm408
Sep 11, 2008 8:55 PM
bdm408
Sep 7, 2008 6:24 PM
