99 suburban sway bar links
Old Aug 31, 2013 | 5:34 PM
ebacon's Avatar
Default 99 suburban sway bar links
I am attempting to replace the links on both sides. The frame is supported on jack stands with both front tires off the ground. The problem I have is the upper control arm is absolutely in the way. I can not put the bolt in from the top down and I can not get enough clearence to get the nut on from the bottom up. I have the exact same issue on both sides so I do not believe the bar is twisted. Yesterday I had replaced passenger side only and the top of the bolt was pushing on the upper control arm. So today i temoved the new link and cut out the old. but now i can not get enough clearence between UCA and swaybar to atrach nut on either side. This seems like a simple repair but the UCA is 100% in the way. What am I doing wrong?
SOLOLUCKY
Apr 16, 2015 10:32 PM
mr280z
Jan 26, 2015 11:06 PM
timabrams
Uplander
Dec 7, 2011 4:11 PM
Classical Glass
Sep 2, 2007 11:09 PM
Classical Glass
Aug 8, 2007 7:31 PM
