ABS Issue
Old Dec 21, 2014 | 11:00 AM
71Corvette's Avatar
Default ABS Issue
I know this topic has been discussed here a hundred times but I'm having some persistent issues with the ABS engaging at low speeds (5 mph or so) on my 2004 Silverado.
I've cleaned the hub surfaces for both front wheel ABS sensors based on the GM service bulletin. While I did that I also had the battery disconnected for a good long while. After putting it back together I took it for a test drive and everything worked fine for about 5 miles and then the same problem popped up again.
Next I replaced both ABS wheel sensors which yielded similar results. It fixed it for about 5 miles and then the same problems popped up.
I'm going to double check the resistance of the ABS sensors today to verify they meet specs but I thought I'd post here to see if anyone has any other ideas. I'm at a loss at this point. I thought I remember hearing there's a third sensor on the transmission but I'm not sure if that's true or not.
Also, the ABS light isn't illuminated on the dash.
Any ideas would be greatly appreciated!
its.all.hers.chevy
Oct 22, 2014 9:18 AM
DBJTS
Feb 26, 2010 11:11 AM
ladder_vent
Dec 15, 2009 4:08 PM
Vilocty
Jan 7, 2008 10:21 AM
mastar91169
Jun 4, 2007 10:38 AM
