ABS Pump
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
//--></>The ABS pump stayedon after turning the engine off and the ABS light was on. I pulled the fuse out and the pump shut off but now the amber ABS light and the red Brakelight are on all the time. I was told it could be a bad sensor. Where are the sensors located at the wheels and is there a simple or easy way to remove and or check each one of them?
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
<edited><editID>arkie</editID><editDate>38586.9225347222</editDate></edited>
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
I don't think the sensors are the problem, they usually cause an overactive abs while braking or none at all. Motor running all the time sounds like the BPMV needs to be replaced. Have it diagnosed properly cuz they are expensive.</P>
