AC control questions
Old Sep 7, 2008 | 6:41 PM
Ditch Bitch's Avatar
Default AC control questions
Have a '01 Silverado 1500 with the 5.3
Bought the truck about 3 weeks ago. One of the problems ive noticed is that the ac nor heat will blow out when the dial is set on fan speed #1. Works fine for the rest of the number.
Though sometimes when i turn it off, i think i still feel it blowing out slightly, almost like its on fan speed 1.
Another problem is when i sit still or first start the truck and let it sit and idle, the AC wont get cold. Just blows hot until i put it in gear and start driving.
Any ideas? I was thinking maybe a vac leak somewhere, but im not to familiar with these trucks yet. This is my 1st Chevy, owned nothing but fords before this.
Old Sep 7, 2008 | 8:17 PM
ukrkoz's Avatar
Default RE: AC control questions
having 2000, which is same, i have 2 guesses for you:
1. close air flow through all the vents except driver side very left and center one. ALL, including ones in the rear.
this truck has inadequate air flow in blower 1 position. not enough for the size. but if it all works fine, you'll see in about 15 min, that 2 is too much, actually
2. your freon level is lowerish, so to speak. it works, just lacks enough juice. thus, when there's no air flow from driving, you have poor feon cooling/warm air blowing.
i'd add one small can of freon/oil mix to the system. JUST ONE!!! and the smallest they have. you overcharge it - you jamm it.
Old Sep 9, 2008 | 11:03 PM
x1cn18's Avatar
i have a 2000 model and mine did very similar except 1 and 2 quit it was the blower motor resistor below the dash next to the motor there were burnt tracec on it as far as the rest im not too sure
Old Sep 15, 2008 | 10:06 PM
ORIGINAL: ukrkoz
Closing all the vents and blower #1 i have nothing.
Ill have the A/C recharged at my work, see if that solves the other problem.
hyperlite91193
Nov 8, 2022 10:20 AM
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
kbridge234
Sep 4, 2008 10:03 AM
gotmyhoe
Jan 7, 2007 5:48 PM
