AC issues - Blows cool, then hot when at idle.
Old Jul 15, 2011 | 10:36 AM
Night Train's Avatar
Default AC issues - Blows cool, then hot when at idle.
I posted this a while and didn't get any responses so I'll give it a 2nd try.
1997 C1500 2WD 5.7L. The truck AC runs fine when truck is moving. After sitting (only on hot days) for 5-10mins it'll start blowing hot air. So in bumper to bumper traffic here in Texas at 100+ degrees, I'm screwed. Once traffic clears up I have to shut everything down and drive for about 5-10mins then turn it back on. At that point it'll start blowing cold.
I mentioned "only hot days" because at night, temps below 80 I can't let it sit idle and the cold air stays consistent.
Any ideas?
Old Jul 15, 2011 | 11:07 AM
slw210's Avatar
Most likely low coolant. Hook up some gauges and check it all out.
Also you might want to check the rest of your components. Could be a sign of something going out like the evaporator, condenser, etc.
Old Jul 15, 2011 | 3:07 PM
GM Fixer's Avatar
YUP! Low on Refridgerant R134a? my truck does the same thing
Old Jul 16, 2011 | 1:19 PM
Ok gang. I pulled out my guage and tested it. It wasn't low. In fact ot was about 85% and to be certain about coolant level, I added more without without hitting the red area.
I then ran the truck for a while mid day today, then let it sit in my driveway and started blowing warm air after about 15-20mins.
Any ideas?
Old Jul 16, 2011 | 2:01 PM
kevinkpk's Avatar
Any ideas?
With it setting in idle, blowing hot air, with a/c on, is the compressor clutch engaged? If not, and I suspect not, check for voltage at the clutch electrical connector, if you don't have 12 volts there, check for a low pressure cutoff switch issue. I don't think temp has anything to do with it.
davidh11
May 30, 2021 4:11 PM
muddbug1
Aug 21, 2013 11:55 AM
Buckmaster73
Jun 28, 2012 9:09 PM
jennkent5454
Jan 12, 2010 5:41 AM
snowonweb
Oct 25, 2008 3:42 PM
