Adding a Sub to Bose System
Old Mar 10, 2005 | 7:18 PM
gus_gus18's Avatar
Default Adding a Sub to Bose System
I have a 2004 Silverado LS with the BOSE system. I wanting to add a sub and amp to this system. I have read that it is possilbe, and was wondering if anybody has done this or knows how to do it? </P>
Thanks</P>
Old Mar 21, 2005 | 12:30 PM
chrisselfz71's Avatar
you have to but a speaker to rca converter. wire it in with one of your back speakers and there is your rca connections. you really are going to need a stand alone crossover so dont get cheap on it or you will hurt the sub!!! Do not mix your bass and your mids!!!
Old Mar 21, 2005 | 9:26 PM
Patrick's Avatar
if the system hasa factory amp, you may need to install the RCa convertor before the factory amp...i know with some vehicles, and a good enough amp (with a built in adjustable crossover), you do not need the RCA convertor...the way you will know, take a speaker wire from one of your rear speakers, and hook it up to your amp/sub...if it hits like it should, it will be fine...i have an expensive amp with a crossover filter, so i didnt bother installing a stand alone crossover...
Thor2003dirty
Jan 17, 2015 7:15 PM
SirKaboomski
Jun 9, 2013 10:57 PM
eggthief
Apr 12, 2012 8:47 PM
Havocide3
Mar 23, 2007 11:52 PM
