Old Jul 22, 2015, 10:54 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
Air filter Replacement
Old Jun 10, 2013 | 1:36 PM
915chev's Avatar
Default Air filter Replacement
Are air intakes really worth getting? Or should i just get the Air filter replacement?
I saw that K&N has a replacement filter and so does Airaid, Which one is better out of those two?
I drive a 2012 silverado crew cab/4.8l. by the way
Thanks in advance..
Old Jun 10, 2013 | 2:18 PM
total waste imo. In addition, alot of cai systems will set numerous drivability dtc on the newer trucks. You will not notice any power increase; all they do is look nice. They are not functional. Some cai don't even isolate the filter from underhood hot air. Oiled filters crude up the maf sensor...only use these on speed density fuel metering systems. Stick with a oem air filter only...not even conventional aftermarket filters made to fit the oem air filter box.
Old Jun 14, 2013 | 1:26 AM
iluvchevy's Avatar
CAI can be considered as a good investment, but there are other factors that you need to consider/upgrade in order for you to see big improvement on your ride.
Old Jun 15, 2013 | 10:18 AM
cleveland63b's Avatar
agreed, almost all of them ive seen/installed pull air from warmer locations than stock does theres nothing "cold air" about them. For day to day driving there wouldn't be a noticeable difference other than maybe a little more noise under the hood. Don't remember the exact formula but under perfect conditions it takes a 7 degree drop to gain 1hp, so even the few that may pull colder air you might get 2 or 3hp for like $300...not worth it
Old Jun 17, 2013 | 8:52 AM
915chev's Avatar
Great thanks guys... really good info...
i think ill just stick to oem then.. maybe just get a replacement filter for it.. cuz it is dirty!! lol
Old Jun 17, 2013 | 9:28 AM
Write the date that you installed the filter on the side of the pleating of the filter, that way when you check it and even if it looks clean if its more then a year old you'll know to replace it... my 2¢
On a side note, some CAI systems remove the stock air baffle(s) so the air coming into the engine can make a throat-er sound much like changing the exhaust...
silverado 1500 2001
Sep 14, 2014 7:41 PM
tcr1016
Jan 29, 2011 7:06 PM
Gaidin43
10
May 29, 2009 1:12 AM
CUTMAN100
HHR
Aug 29, 2007 8:03 AM
clint59
Cobalt
Aug 24, 2006 5:14 PM
