Air flow
Mode door actuator is on the left side of the hvac case near the gas pedal . It has a large cam on it and can be seen if you lay in the floor on the driver side.It can be replaced without the cam if you are very careful ,otherwise you will need to retime the cam to the door cam. Do you have automatic hvac or manual. If its auto ,have the programmer checked for update before you replace actuator and check connectors in the RH. side of the dash behind the side panel.
chevykid06
Jan 6, 2007 3:50 AM
