Notices
air fuel gauge
Old May 20th, 2009, 8:20 AM
516rider's Avatar
Default air fuel gauge
hey i just bought an air fuel gauge for my truck. and i was wondering what wire on the o2 sensor i need to tap my wire into?
Old May 20th, 2009, 12:26 PM
Professional Mechanic
MDTAHOE's Avatar
What do the instructions say? Does it say signal wire? What year is it? What size in the engine?
Old May 20th, 2009, 12:48 PM
ROTM Coordinator
Mike Sigmond's Avatar
What model is the guage? here is some info on installing them.
http://neptune.spacebears.com/cars/s.../scagauge.html
Old May 21st, 2009, 6:14 AM
516rider's Avatar
its an 04 with the 4.3 in it the gauge is autometer ultralite. it need to tap into the powertrain control module wire that leads to the o2 sensor. i have no clue what that module is or where i can find it
Old May 21st, 2009, 10:14 AM
ROTM Coordinator
I wish I knew more about them, looks like a neat moniroring tool/guage.
Old May 22nd, 2009, 2:20 AM
racerx55's Avatar
IMO the narrowband cheapy ones are more for looks. but thats ok for some.
wideband is the only way to go unless your just leaving everything all stock and no type of tune adjustments. powertrains control module (PCM) is your ECU, computer ECM whatever you wanna call it. i cant find the page i had with the pinout for them or i would link you to it. you may be better off tapping directly to the 02 sensor itself by tracing back the wire rather than chopping into the factory ECU harness. you can pick any of the upsrtream (pre cat)sensors, dont use the post cat sensors.
Old May 22nd, 2009, 7:43 AM
516rider's Avatar
what is a pre cast sensor and a post cast sensor. i figured i would just tap into the o2 sensor. but i have like 4 wires going to it and im not sure witch one will give me my reading. i thought about tapping into all of them at once. but that might screw up all my readings to my ecu.
Old May 22nd, 2009, 8:38 AM
racerx55's Avatar
pre cat - are before the catalaytic converter(s) post cat are after. you want one before a cat. dont do one at a time, if you tap into the positive heater wire you will smoke the gauge. i cant remember what colors do what, ill see what i can find. or maybe someone else will chime in that knows which color wire.
Old May 22nd, 2009, 10:37 AM
ROTM Coordinator
Well 2 wires are for the heater in the O2 and 2 are for the signal ( in & out) you need to find the out signal, if you tap into the heater line it might fry your guage. I will look in a little bit if someone does not tell you which one it is before me.
O I see racerx55 just said that,...
Old May 22nd, 2009, 11:55 PM
516rider's Avatar
yea if i knew what wire to go to. it would help. i dnt wanna fry my gauge. or send a signal to my ecu that may screw things up.
Quick Reply: air fuel gauge
