air fuel gauge
#11
ROTM Coordinator
ROTM Coordinator
Thanks for the reminder
In my manual an 04 model has these color wires:
Bank 1 Front sensor before cat
Tan/white
Purple/white
Blue
Pink
Bank 2 After cat sensor
tan
purple
blue
white
I believe the tan & purple ones are the signal ones & the blue and pink solid ones are the heater.
Please let a ASE tech or experienced member here verify this first, If I have it backwards and the tan & purples are the heater you will fry it.
I hope this helps understand it
Here is an example of how it works...
Tan/white
Purple/white
Blue
Pink
tan
purple
blue
white
#14
ROTM Coordinator
ROTM Coordinator
Well the pink & blue ones go straight to a fuse & ground in the diagram which makes me feel they are power for the heater, the tan & purple ones go the computer harness, upstream & downstream signal. The stripes just are for the bank 1 sensors.
Just my 2 cents about it.
#16
ROTM Coordinator
ROTM Coordinator
I am not sure. I think the engine needs to be running for them to power up. In cold start they will be in open loop for a minute or so until the 02's heat up, once they close they begin sending a signal.
#18
ROTM Coordinator
ROTM Coordinator
If it were me I would tap the wires and look with a voltmeter first, I assume the heater wire will carry 12-14 volts from the fuse panel and the signal wires should have a 0-10 or 0-5 volt variance, at least that is how computer signals work on most applications I have worked on.
#20
ROTM Coordinator
ROTM Coordinator
My guess is the downstream will not change, maybe 5 or 10 volts solid, the upstream is the signal back that varies fom 0 to whatever volts. maybe I have it backward but if both these are the signal wires just tap the one that fluxuates when the motor is running and being driven. Make some lead wires long enough to have the meter in the vehicle when verifying you have the right wire.
