Anti-Knock Sensor
Old Aug 31, 2009 | 6:15 PM
randyrt's Avatar
Default Anti-Knock Sensor
Hi,
Can someone tell me where the anti-knock sensor is on a 2001 Chevy Silverado? Also, is there a way to test the sensor or do I just replace it?
Thank you!
Old Aug 31, 2009 | 7:48 PM
MDTAHOE's Avatar
Professional Mechanic
5.3 liter? If so under the intake. To test you need a DVOM set on the AC voltage scale. Put the red wire on the knock sensor and the black wire on ground. Tap/ hit the engine block with a metal hammer as close to the sensor as you can. If the sensor is working it will generate AC voltage the harder the knock the higher the voltage.
Old Sep 1, 2009 | 9:30 AM
randyrt's Avatar
Thanks MDTahoe I'll see what I can find. randyrt
jdog
Dec 10, 2024 12:11 AM
jffgin
Mar 10, 2008 2:32 PM
desilverado
Mar 24, 2007 4:10 AM
jamesdal7
Jul 18, 2006 11:11 PM
