antifreeze drip
Old Feb 16, 2014 | 10:14 AM
terrya's Avatar
Red face antifreeze drip
I have a 2013 Silverado 1500 Ext. cab. Where the cab mounts to the frame on the rear driver side, the bolt is constantly damp with antifreeze (I had our chemist at work test it). Took it in and the dealer pressure tested the system and it passed, but I still get the spot on my garage floor daily. Any advice I could take back to them would be appreciated, unless this is a first. Thanks
Old Feb 16, 2014 | 11:16 AM
Richardx2's Avatar
Heater core leaking inside? Is the carpet wet?
Old Feb 16, 2014 | 11:34 AM
IF the system really pressure tested good, then it might also be the overflow tank leaking, but that is on the passenger side of the vehicle for GMT900....
I would go with Richardx2 suggestion and investigate the top side of that area... but do check the over flow tube of the tank and make sure its not running down the frame and finally dripping at your bolt point...
Old Feb 16, 2014 | 7:00 PM
terrya's Avatar
No wet carpet, thanks. Thinking it maybe following the frame back????
Old Feb 16, 2014 | 7:12 PM
terrya's Avatar
They pumped it up to 30 psi for 30 minutes and it held. As slow of drip it is, maybe this wasn't long enough to show. Where the drip shows, maybe it's following the frame back. Seems it's more obvious after a half hour plus drive and I see it the following morning...nothing immediate. Thanks and keep thinking...I am.
96 Junk That Moves
Dec 15, 2014 8:58 PM
Earl Ricky
Sep 14, 2010 10:59 AM
Iajeeper
Mar 3, 2007 5:06 PM
jorgie5150
Jan 27, 2007 5:18 PM
kdeinv
Dec 31, 2006 10:09 PM
