Antifreeze leak
Old May 9, 2010 | 1:49 PM
Jakester's Avatar
Default Antifreeze leak
04 Silverado has a slow leak of antifreeze that leaves small spots on garage floor right under front passenger side of motor. Lots of crawling around to find source I'm hoping someone has had this issue that can diagnose.
Old May 9, 2010 | 6:57 PM
72c10gunn's Avatar
check the weep hole on the water pump...if thats the sorce youll need to replace it
Old May 10, 2010 | 2:34 PM
tom5170's Avatar
yeah check the water pump. Mine was in the same exact spot and I couldnt find it. I crawled around all over and couldnt trace it until I looked at the water pump. Mine was from the water pump seals being bad. I ended up replacing the water pump. Paid 30 bucks, and took about an hour to install.
Old May 10, 2010 | 4:56 PM
Jakester's Avatar
Sounds like a unanimous choice - I'll start there. Thanks!
Old May 10, 2010 | 6:06 PM
tom5170's Avatar
let me know if you find anything
Old May 13, 2010 | 4:20 PM
Jakester's Avatar
I crawled around and it appears its coming from the seal around so I will be changing this out this weekend and about $130 bucks lighter with the thermostat to boot!
sunturtle
Jul 9, 2012 10:52 AM
Peter Bistany
Nov 3, 2010 7:58 PM
capsnumber1
Oct 2, 2009 8:59 AM
jorgie5150
Jan 27, 2007 5:18 PM
kdeinv
Dec 31, 2006 10:09 PM
