Any Chevy Mechanics On Here?
Old Dec 27, 2011 | 7:07 AM
Allan In NE's Avatar
Default Any Chevy Mechanics On Here?
1988 K2500 IFS differential, 4:11 ratio.
I've been restoring this old truck, have a "moan" or "humming" type noise in the running gear. Comes in at exactly 42 mph and leaves at 58mph. Sounds like a dry hub bearing seal, but it's not as the truck has been totally rebuilt save the front differential. Front axles "look" okay; no noises when turning whatsoever.
I can lock the front driveshaft from rotating and the noise does not change. 2 wheel or 4 wheel makes no difference at all. Noise sounds like it is right under the seat or perhaps up under the engine area.
Quite a bit of slop (good 1/16") in the left axle stub shaft.
What does a bad axle bearing sound like? Do they "moan"?
Thanks,
Allan
EastsideG6
Nov 5, 2010 12:02 PM
06chevy5.3
Nov 6, 2008 9:59 AM
brocsbar
Jan 5, 2006 2:52 AM
brocsbar
Jan 5, 2006 2:51 AM
