Any recourse?
Old Sep 28, 2005 | 10:35 PM
popnsmo's Avatar
Default Any recourse?
I've got an '04 2500 HD, 6.0 shortbed extended cab with 16,000 miles on it. So far, I've had the brake pedal got to the floor 3times (took 2 dealers to finally figure out it was the hydro-booster) Original dealer thought it was in the ABS system. Replaced ABS sensor in right front and then entire right front hub. Then the transmission locked itself in 2nd gear, they totally rebuilt tranny. Then the rear end sounded like it was going to fall out when pulling 5th wheel trailer around bend in road from dead stop. Dealer replaced fluid in rear end. 5th wheel weighs 7,000 lbs. Truck rated to pull 10,300. So weight should not be anissue.Has any else had similar problems with their '04?<IMG src=smileys/smiley5.gif border="0">
garage08
Sonic (Aveo)
Nov 16, 2007 12:12 PM
Dragon18
Apr 10, 2006 9:00 PM
NovaGuy21
Nova & Chevy II
Jan 10, 2006 5:51 AM
workin_ike
Sonic (Aveo)
Jun 23, 2005 8:27 PM
1 Low X
Oct 25, 2004 8:08 PM
