Old Aug 10, 2015, 7:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
anybody know how to reset idle on a 07 silverado?
Old Mar 1, 2012 | 11:00 PM
94racing's Avatar
Default anybody know how to reset idle on a 07 silverado?
so i put new cats on to resolve my last problem and the engine light came back on p0121 throttle position sensor ckt A
i opened the throttle body up and cleaned it out and spayed the sensor down with napa "electrical parts cleaner". reinstalled on my truck and i started the truck up and it idled at 1500 rpm i put it in gear and it dropped down and stayed at idle again but if i touch the gas it will shoot up to 1500. put a new throttle body on it today and drove 90 miles and still the same. so i followed a procedure i read by: pulled the pcm fuse out and let it sit for 5 mins then put it back in let it idle in drive with the parking brake set for 5 mins then a/c on full blast for 5 then a/c off and in park for 5 then shut it off like i read in another thread. still does the same thing and i noticed after i drove it around some back roads and highway(about 50 miles) that if i put it in drive from a stop it would take off and pull itself up a decent hill and power its way to 3rd gear on a flat surface. also slipped it out of drive into neutral a few times and rms would shoot up to 3000 rpm till the vehicle would come to a stop then it would slowly drop to 600.
any help would be appreciated.
its going into the dealership tuesday for computer work is there any way for them to adjust the idle in the short time they are fooling with it?
truck info.
2007 chevy silverado (newstyle) z71 4x4 5.3 with the M 8th digit.
if i left any information out let me know. im going to drive it 90 miles again tommoro.
Old Mar 2, 2012 | 7:02 AM
procharger camaro's Avatar
It has to go to the dealer to be relearned with the scanner! I just had 2 trucks at work with the same prob!! i tried everything! even with 2 weeks of driving thinking it might relearn on its own, but no they didnt.Took to dealer and took 40min. to reset and good to go! Modern technology such a good thing LOL.
Old Mar 2, 2012 | 7:40 AM
94racing's Avatar
About how much did that run you? Im out of warranty
Old Mar 2, 2012 | 12:35 PM
94racing's Avatar
103 to program the idle. Ill just leave it till it gets bad maybe it needs to program itself
Old Mar 3, 2012 | 9:27 AM
here it only cost 89 bucks tax included!
Old Mar 3, 2012 | 5:45 PM
cleveland63b's Avatar
did you reinstall the TPS the same it came out? It haven't done an 07 but sometimes you have to kind of "clock" them just right or the sensor will be out of adjustment.
Old Mar 3, 2012 | 7:29 PM
94racing's Avatar
Its back in sync with the truck. Works fine now. I drove it about 200 miles
Old Mar 3, 2012 | 8:03 PM
Exhausted's Avatar
A local tuner can do it with efi live or hp tuners
Mine charges 25bucks
Old Mar 4, 2012 | 3:35 PM
ukrkoz's Avatar
out of curiosity - is it a drive by wire system? gas pedal on 07?
Old Mar 5, 2012 | 5:37 AM
yes they are! personally i dont like that system.
