Anyone know how to remove a broken power steering pulley?
Old May 17, 2008 | 10:24 AM
bgpunk2001's Avatar
Default Anyone know how to remove a broken power steering pulley?
I have a 95 3/4 ton silverado and I was using a power steering puller to take the pulley off. Well, the lip of the pulley broke and the screw for the tool is stuck in the pump (axel).
It looks like taking off the pulley is the only way to get the pump off, is this true? If so, how can I get the pulley off? Any help would be greatly appreciated.
Old May 17, 2008 | 3:47 PM
northey87's Avatar
Default RE: Anyone know how to remove a broken power steering pulley?
Welcome to the forum!!! I am giong to asume that you are trying to take the power steering pump out, you should be able to take the belt off the engine and the pump should unbolt right out.
Old May 17, 2008 | 10:57 PM
RonH's Avatar
You are probably have to get a large gear puller that will grab the outer edges of the pulley or use some kind of wedges behind the pulley. As you know it's just a force fit, so just force it off. Too much force and you may ruin the pump (if it't not already runied), so go as easy as you can.
Old May 20, 2008 | 10:53 AM
old dog's Avatar
why are you taking the pully off?do you already have the pump out of the truck ?is the pump shot ?if the pump is shot and you are trying to change the pully ,you may have to use a clam shell bearing puller with any approite shim's with through threded rod's to the puller and lightly heat the pulley were it goes over the shaft to relax the press fit .it's hard to guess whith out knowing what you are trying to accomplish .
Tania
Jun 8, 2010 3:04 PM
brylamca
Jul 24, 2009 1:03 PM
BMoTahoe
May 1, 2008 8:48 PM
osiris204850
Nov 1, 2006 9:42 PM
Top
Follow Us
