Backfire and Miss
Old May 7, 2011 | 5:40 PM
Clay2026's Avatar
Default Backfire and Miss
1999 chevy silverado LS Z71 1/2 ton 4x4 5.3 eng. I have a backfire and Miss when hard throttle or pulling a grade on a highway. Check Engine Light On Too! Changed plugs and useing the E3 plugs, it ran great for 4 months and this problem has arrived... Thanks for the help! Clay
Old May 8, 2011 | 8:22 PM
country_09's Avatar
the e3 plugs are crap...go back to ac delco. they'll last longer. what other codes popped up?
Old May 13, 2011 | 7:27 PM
Clay2026's Avatar
Cleared codes but they were P0300 Random cyl. misfire and P0332 Knock sensor 2 circuit low input bank 2...... I bought AC Delco plugs today n will install soon.. After clearing codes it does run better but still misses n backfires when getting on it or pullin a grade on hyway. Thanks for the help...
Old May 14, 2011 | 2:22 PM
country_09's Avatar
the knock sensor is fun to change...its under the intake manifold. very common problem with silverado's 99 and up
Old May 20, 2011 | 4:56 PM
Clay2026's Avatar
Installed AC Delco plugs, reset codes and runs great, E3 Plugs are junk! still getting knock sensor code tho.. Thanks All Clay
Old May 20, 2011 | 6:29 PM
Rez's Avatar
Rez
mine did a similiar thing when i installed bosch oxygen sensors. problem disappeared when I replaced them with AC Delco brand oxygen sensors.
glad you got it figured out.
QBert
May 5, 2021 10:00 PM
briefox89
Dec 29, 2010 12:51 PM
firecap
May 11, 2009 12:36 PM
survivaldog
Dec 7, 2008 4:44 PM
rustedduck
Oct 3, 2008 10:45 AM
