bad injector?, miss, runs rich,help!!!
I have a 2000 3500 truck with a 7.4 litre. have done complete tune up,yet still runs rich with a miss at idle. runs almost perfect otherwise (but killing whats left of the already poor mpg). I can smell gas from the exaust pipe. the spark is strong &steady on all cylinders. but when I disconnect the wire from #5 there is very little change while its running. therefore I suspect the injector. Any input? If the injector is the culprit how much is involved to change one? anyone had good results with injector cleaner? thanks
RE: bad injector?, miss, runs rich,help!!!
There is a recal on most chevy injectors and a few distributer. GM routed the AC accumulator line directly over the cap and when running ac the line collected moisture and dripped on the cap shorting and burnin it up.
donaldo
August 14th, 2015 11:06 AM
Chev_Hoe
January 14th, 2014 9:41 PM
