bearing noise?
Old Oct 9, 2012 | 8:32 AM
GM Fixer's Avatar
Default bearing noise?
2004 5.3L there is a noise coming from the frt sounds like a pulley is there a common bearing that goes bad ? noise does go away
Old Oct 9, 2012 | 8:53 AM
NeedMoTools55's Avatar
From: Physically in Norhtern VA, my heart is in SW Virginia.
Look for a red dust build up around the alternator and the tensioner pulley. Good indicator of which is headed south. A bearing failure in the alternator can cause metalic dust build up and mess with voltage oputput. First indication will be a very faint flickering of the headlights and or dash lights. Watch out for that turning fan when under the hood.
Old Oct 9, 2012 | 9:11 AM
67Motorcat's Avatar
It also could be as simple as needing a new serpentine belt.
They can make weird sounds that mimic bearing noise.
Old Oct 10, 2012 | 11:31 AM
Georgiaboy04's Avatar
I have an 08 silverado 4x4 I had the same type noise when I was running the truck I could hear it mostly when I decellerated. It ended up being my pigeon bearing, it was covered under warranty thank god and my rear diffs were replaced
Old Oct 10, 2012 | 8:18 PM
cleveland63b's Avatar
its pinion bearing just fyi
as for the original post you can talk and look for dust all you want, pull the belt off and spin each pulley by hand you'll be able to hear and maybe feel the bearing in the bad pulley (if 1 is in fact bad)
Old Oct 11, 2012 | 5:19 AM
grumpychevy's Avatar
^ yep, mine ended up being an alternator bearing going bad.
tommadeez
Mar 8, 2014 7:47 AM
stb100
Apr 3, 2013 7:28 AM
tpothen
May 17, 2011 3:19 AM
skippybriggs
Jun 25, 2010 9:50 AM
GunnerNK
Jun 28, 2008 11:21 AM
