Both knock sensor codes
Old Feb 7, 2011 | 8:34 PM
hondaman's Avatar
Default Both knock sensor codes
I bought a 01 silverado 4x4 with 5.3 128000 miles and ses light came on had it scanned and threw codes for both knock sensors,motor sounds fine any ideas i have heard water gets in there but does it normally make both go bad.any help please.
Old Feb 8, 2011 | 10:59 PM
silveradok1500's Avatar
I have the same thing going on. My ECM threw a PO327 code. After reading about this issue, I pulled off my intake and both knock sensor wells had water in them, and major corrosion going on. Replaced them with OEM parts, along with cable, and thought I was good to go. Now I am still getting the SES light and po327 code?? Trying to figure out what else is causing this code to come up??????
Old Feb 14, 2011 | 4:11 PM
hondaman's Avatar
well i tore it apart checked both knock sensor and harness sensors were bad harness was good so put in new sensors and gaskets and so far no ses light .
Old Jun 17, 2011 | 12:46 PM
BabiedSilverado's Avatar
How's it going, Hondaman? I've got an '01 1500 with the 5.3L and 209k miles on it. Best truck I've ever owned. But, my service engine light is on again and the OBDII indicates its a knock sensor problem as well. The mechanics are telling me that the knock sensor code is coming up because of some other unknown problem thats causing it. In the meantime, they want hundreds of $ just to diagnose it. Was wondering how you made out with replacing yours or if you found other problems since then.
Old Jun 18, 2011 | 7:34 AM
hondaman's Avatar
Mine is still running good no ses light guess I got lucky
Old Jun 18, 2011 | 3:39 PM
country_09's Avatar
if you fix the knock sensor, you're suppose to clear the codes and they shouldn't come back. If they do then you didn't do somethin right
guariscoc
Sep 28, 2011 5:48 PM
jffgin
Mar 10, 2008 2:32 PM
chevrebuilt
Oct 7, 2006 4:30 PM
