Brake Pedal still spongey...93 Sierra
Bought a 93 Sierra. Prior owner said they tried to bleed the brakes over and over. Pedal felt like primary piston was failing, secondary kicking in. Thats where it catches with initial push, then fails then re-cathces. I replaced the master cylinder and have bled them three times. No better than before the replacement of master cylinder. Do I have bad calipers? WTH?
If you bleed them and there's still no pressure your calipers are worn out and exhaling to much. Check to see if the pads are in slight contact without the brakes on. If not you probably need new calipers.
next2nothing000
October 10th, 2021 9:25 AM
oldtruckgoodtruck
August 21st, 2016 9:04 PM
98Silverado1500
August 3rd, 2012 7:25 AM
SuperTexan
November 4th, 2008 11:24 PM
