Brake Pedal still spongey...93 Sierra
Old Jun 21, 2012 | 6:05 PM
SuperTexan's Avatar
Default Brake Pedal still spongey...93 Sierra
Bought a 93 Sierra. Prior owner said they tried to bleed the brakes over and over. Pedal felt like primary piston was failing, secondary kicking in. Thats where it catches with initial push, then fails then re-cathces. I replaced the master cylinder and have bled them three times. No better than before the replacement of master cylinder. Do I have bad calipers? WTH?
Old Jun 21, 2012 | 6:34 PM
kevinkpk's Avatar
Not sure with the "newer" stuff. Is there a porportioning valve on the MC?
Old Jun 22, 2012 | 6:25 AM
Mudd Mutt's Avatar
If you bleed them and there's still no pressure your calipers are worn out and exhaling to much. Check to see if the pads are in slight contact without the brakes on. If not you probably need new calipers.
next2nothing000
Oct 10, 2021 9:25 AM
oldtruckgoodtruck
Aug 21, 2016 9:04 PM
98Silverado1500
Aug 3, 2012 7:25 AM
SuperTexan
Nov 4, 2008 11:24 PM
junL
Mar 14, 2008 7:42 PM
