Brake problem on 2002 Silverado
I have a problem on my 02 Silverado that I can not figure out.
The pedal will be fine for a bout a day or two and then for some reason at random it will just go to the floor and nothing. If i pump them up they will eventually get better but a day or so later it will be right back to where it was with the brakes going to the floor. So far I have replaced the power booster, the master cylinder and bleed the brakes many times.
I am confused as to what it might be and any help would be great thanks.
I would check the bqnjo bolts going into the calipers. There may be air getting in.
I think there should also be crush washers, 1 on either side of the brake line, try replacing the crush washers.
jg33
January 3rd, 2021 3:17 PM
Greg O
September 8th, 2006 2:21 AM
ffarv
April 9th, 2006 1:52 PM
