Brakes quit working in an instant weird circumstances????
Old Oct 26, 2009 | 5:52 PM
Gixxerific's Avatar
Default Brakes quit working in an instant weird circumstances????
I was turning around on a street in a new subdivision when I dropped my front passenger tire off the road into a small ditch. It wouldn't back out on it's (wet and muddy). I put it in 4x4 and pulled right out no problem. I put it back in regular drive and took off home. At that instant I realized my brakes were not working well at all. Than I noticed my brake waring light was on. I get home and check the fluid, the front (smaller res.) is empty. I also checked as good I could the lines they seem to be fine without any breaks.
I'm boggled could there be something with the transfer case for some reason. I put it through it's paces at home when I put it in 4-low than back to regular it was grinding, i did have it in neutral at the time.
Old Oct 26, 2009 | 6:38 PM
Speedy650's Avatar
check around the lines at suspension, steering components, and whatever else to see if the line broke and was spurting fluid. also check line junctions to see if one cracked enough to drain the fluid.
metransue
Jan 8, 2017 12:42 AM
drbydriver
Dec 23, 2012 2:13 PM
sdfd504
Apr 24, 2011 3:02 AM
vbph
Oct 24, 2006 6:06 PM
funky_junk
Sep 23, 2006 1:56 PM
