Bright lights
if you reffering to high beam then it is due to blown fuse or a bad relay. If the high beam fuse has blown, it'll need to be replaced and the circuit will need to be inspected for problems. Or, it could be a bad relay. If the headlight relay has failed, it may not respond when you attempt to switch the high beams on.
oilcanhenry (November 18th, 2022)
topwhop1977
August 7th, 2010 5:10 PM
