Bright lights
Old Nov 16, 2022 | 2:03 PM
Basser8509bf's Avatar
Default Bright lights
My 2007 2500 Silverado bright lights do not come on when selected: the lights do work when the flash feature is used.
Suggestions?
Old Nov 17, 2022 | 1:35 PM
oilcanhenry's Avatar
Suggestions?
I'm unclear on what you mean about bright lights (high-beams?) I'm also unsure about the flasher comment. Can you elaborate?
Old Nov 17, 2022 | 11:31 PM
davidjohn's Avatar
if you reffering to high beam then it is due to blown fuse or a bad relay. If the high beam fuse has blown, it'll need to be replaced and the circuit will need to be inspected for problems. Or, it could be a bad relay. If the headlight relay has failed, it may not respond when you attempt to switch the high beams on.
tweber27
May 22, 2017 1:16 PM
Chooch chillali
2007 - 2013 (GMT900)
Jun 12, 2016 11:03 PM
Bets
Jan 2, 2011 7:20 AM
topwhop1977
Aug 7, 2010 5:10 PM
boomerbsg
15
Apr 1, 2008 8:39 AM
