A/C control head reset
Hi guys,
I have a '91 C1500 (GMC Sierra) with a flashing "A/C" indicator on the control head. The A/C was cooling fine, then all of a sudden it quit and the indicator started flashing. The owner's manual says it's a low refrigerant warning, but it doesn't say how to reset it. I used to work on these things, but I've been out of the shop for several years now, and don't remember how to reset it. Please help! Good luck and God Bless,
Tommy
Tommy
RE: A/C control head reset
I tried pulling fuses, but then I found out that the battery power to the control head doesn't have a fuse in the fuse block. It turns out that disconnecting battery power to the head did the trick. I could have pulled the control head, or disconnected the battery to do the job. I found a 3 wire connector up beside the blower motor and disconnected it, that way I didn't have to remove the dash trim or lose my radio settings by disconnecting the battery. As far as charging the system, it still cools fine. I guess it was a hiccup of some kind. Good Luck and God Bless,
Tommy
Tommy
Chevrolet Forum News
January 29th, 2015 7:08 PM
December 28th, 2014 6:18 PM
opb
October 21st, 2012 6:42 PM
DOBERDEWD
December 11th, 2011 11:35 PM
