A/C control head reset
Old Jun 2, 2006 | 4:35 PM
Revredneck's Avatar
Default A/C control head reset
Hi guys,
I have a '91 C1500 (GMC Sierra) with a flashing "A/C" indicator on the control head. The A/C was cooling fine, then all of a sudden it quit and the indicator started flashing. The owner's manual says it's a low refrigerant warning, but it doesn't say how to reset it. I used to work on these things, but I've been out of the shop for several years now, and don't remember how to reset it. Please help! Good luck and God Bless,
Tommy
Old Jun 2, 2006 | 11:16 PM
Nomad76lj's Avatar
Default RE: A/C control head reset
would it work if you unhooked the batery. if you dont recharge the system the light may come back on though? something to try
Old Jun 3, 2006 | 10:36 AM
Revredneck's Avatar
I tried pulling fuses, but then I found out that the battery power to the control head doesn't have a fuse in the fuse block. It turns out that disconnecting battery power to the head did the trick. I could have pulled the control head, or disconnected the battery to do the job. I found a 3 wire connector up beside the blower motor and disconnected it, that way I didn't have to remove the dash trim or lose my radio settings by disconnecting the battery. As far as charging the system, it still cools fine. I guess it was a hiccup of some kind. Good Luck and God Bless,
Tommy
Chevrolet Forum News
Jan 29, 2015 7:08 PM
Dec 28, 2014 6:18 PM
opb
Oct 21, 2012 6:42 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
NovaProject
Nov 6, 2010 12:35 PM
