A/C refrigerant leak
Yea, i did manage to charge it and it cooled pretty good compressor was running very quietly but it leaked out a day later. Im gonna look at the eval coil?? are there any known ac leaks on these trucks that keep popping up you know of?
On a truck that old, it could be about anything, but finding the source is not unlike finding any other fluid leak. Look for areas that appear wet or have dirt/debris stuck on them. If it’s leaking fast enough to lose the charge in a day, it shouldn’t be too hard to see.
It may help to remove the grill and air box to get a clear view of the condenser and lines.
If nothing else, get a UV dye charge to trace it - with large leaks, it’s easy to see the source without actually needing a UV light and glasses.
There are all kinds of o-rings that go bad. I just hope its not the evaporator. That means pulling the climate control box and is one of the most expensive A/C components to replace due to all the labor involved. They don't go out often but they do go out on occasion. I'd try the leak finder first. If you pull the condenser just chuck it for a new one, like Gumby said. Get a new orifice valve with might come with the condenser, as its the lower tube on the condenser. Put some PAG 150 oil on it and gently affix it into the connection.How much PAG 150 did you add with the new compressor?. If you are REAL lucky it'll leak out and show you where its leaking but dont count on it as a new system only holds 8 oubces of oil..
there with nothing to do during the hot months and so on, Evaporators going out are usually the result of moisture/air in the system.
albinorhino00
April 1st, 2005 3:20 PM
