Cab Lights Inop
Old January 12th, 2012 | 4:37 PM
1Ton-K1500's Avatar
Default Cab Lights Inop
Cab lights quit workin on my 97 All other running lights work, got power and ground at each light. Switch assuming is good cuz all other lights work, from what and how much i can see I dont have a pinched wire all fuses good. Bulbs look good, the odds they all burn out at one time in one trip???..wouldnt think so.
Old January 12th, 2012 | 4:58 PM
Mille Racer 69's Avatar
You said you got power at each light but the lights dont work?
well sounds like you have some bulbsto replace.
I have never tried it before, but you can ohm out the bulb itself in between hot and ground.
there should be an element in it which creates light. But if it's burnt out, it will
likely have no connection between + and - and you will read ifinite.
$tearman
December 29th, 2014 7:07 PM
rjcisternas
November 11th, 2012 8:30 PM
realbadchevy
August 5th, 2011 4:15 PM
Onetimewill
November 3rd, 2007 8:47 PM
AKKen
February 16th, 2007 10:37 PM
Quick Reply: Cab Lights Inop
