Cab swap
Old Nov 13, 2010 | 9:07 PM
slip13's Avatar
Default Cab swap
Need to no if I can swap a cab from a 75 c20 scottsdale 3 quarter ton with a 77 c20 chyen camper special cab
Old Nov 14, 2010 | 2:30 PM
2wd-K5's Avatar
yes you can, for reference, the only times you will run into problems with swapping that model truck cabs is when swapping between 70's and 80's cabs the hoods are diff and so is the electrical, when swapping between just 70's cabs the thing to watch is putting a 2wd cab on a 4x4 chassis, u will need 3" body lift to do so, when swapping what u have over, just look at the electrical features and make sure they are the sam, if they arent u should use the interior pieces from your truck (if u want them to work)
thx569
Jul 2, 2013 6:53 PM
dpainter68
Dec 7, 2012 10:22 AM
hunsaker41
Nov 9, 2010 10:12 PM
mikewaterskis
22
Oct 10, 2007 8:47 PM
prioritylc
Mar 22, 2007 11:25 PM
