Can high mileage cause a rear main seal to leak?
Old Nov 3, 2010 | 3:38 PM
tom5170's Avatar
Default Can high mileage cause a rear main seal to leak?
I have a 93 silverado with 253,000 miles. I have a oil leak and the oil is leaking between the oil pan and bell housing. I bought the truck back in March and since then just last week I had to add a quart. This is the first time i've added a quart of oil since i've bought it. The engine is probably the original engine that came with the truck. Its a 350 and its very mechanically sound but you can tell its old by looking at it. I have read that the rear main seal can leak because of internal engine damage or whatever... but I also read that it can leak due to high mileage. I am thinking about replacing the seal but I dont want to spend all the money to replace it just to find out that its leaking again because of engine damage.
Old Nov 3, 2010 | 5:01 PM
Mille Racer 69's Avatar
Seals can go bad, nothing really lasts forever, some stuff just can last a lot longer than others.
It is likely due to high mileage. Listen to your engine for a knocking sound or some other bad sound that
Would indicate a mechanical issue. But as far as seals/gaskets go, just get it replaced, it is most likely
Just due to age/mileage.
Old Nov 3, 2010 | 6:27 PM
tom5170's Avatar
Yeah I don't hear any knocking. The engine sounds really good. I get some kind of valve clatter or engine lifter noise a tiny bit when im inside the cab driving... but you cannot hear it from the outside while accelerating. I get a solid rumble from the engine dont hear any noises... although I hear a tiny "whirring noise or wobbling noise" or something under the hood around the engine area. I cant really pintpoint it. It doesnt increase in loudness when im accelerating either. Its just a steady noise so I dont know what its coming from. Its not really noticeable. The alternator and water pump are brand new so it cant be those bearings.
krowe111
Jun 4, 2013 6:25 PM
dkrukosky
Apr 2, 2013 10:52 PM
GregHamilton
Dec 4, 2011 11:35 PM
bnk190
Mar 29, 2009 4:08 PM
