Notices
Car Deck
Old February 22nd, 2007, 10:46 PM
  #11
B1RDMAN's Avatar
Default RE: Car Deck
but do you think the speaker would like blow because i think the stock speakers are not strong enough to handling but on the other hand i dont want to buy 4 new speakers.
Old February 22nd, 2007, 10:53 PM
  #12
sm3earl's Avatar
Well f your bumpin music and your speakers arent that good then yea they will probably blow.
Old February 22nd, 2007, 11:05 PM
  #13
B1RDMAN's Avatar
well than is there a way to check the specs of the speakers? or do you know any site that would have it?
Old February 22nd, 2007, 11:53 PM
  #14
sm3earl's Avatar
the maker of the speakers would have specs.
Old February 23rd, 2007, 1:45 AM
  #15
B1RDMAN's Avatar
and how am i sappose to find that? i type in 1999 chev...speaker spec but cant find anything. do i hvae to open up the speakers and look around to find the specs on it?
Old February 23rd, 2007, 1:48 AM
  #16
sm3earl's Avatar
Yes, you have to look at the speakers, or you can call chevy, im sure they will know. or better yet email them, im sure that will work.
just google your nearest chevy deler then call them.
Old February 23rd, 2007, 4:29 AM
  #17
engine2's Avatar
specs should be on the magnet. unless you have an upgraded factory stereo, I doubt the speakers will handle a 400 watt amp.
Old February 25th, 2007, 12:29 AM
  #18
chevyblues's Avatar
Check with Crutchfield. They have adapters to mount a standard deck and have wiring harness prebuilt to make the install easy.
You can use the OEM speakers but they may have a much higher ohm rating than aftermarket speakers. I've seen some OEM speakers rated at 10 ohm and 12 ohm. Your sound will be much better with aftermarket speakers.
____________
chevyblues
1995 Z71
Old February 25th, 2007, 1:44 AM
  #19
golfer's Avatar
ORIGINAL: B1RDMAN
k thanks but i have one quesion. do you think it would still be okay if i change the stereo to a new deck, keep the original speakers and just hook up amps and sub. the amp is a 400 watt( McIntosh MC431) and the Subwoofer is (JL Audio).
The stock speakers won't handle it ... why do you think they're distorting to be begin with??
Old February 25th, 2007, 1:58 AM
  #20
B1RDMAN's Avatar
when i use the equalizer the music just becomes very f. up. what im plannin to do right now is just install a deck into the truck beucase my cd player doesnt work in that truck. it keeps on saying ERR. sometime it would work and sometime it doesnt. But yea i already bought the custom installation kit to fit the DIN instead of 2DIN. i got the wiring harness that makes it easier to install, and the adapter attenna.
Like what you said that the speaker may handle up to 400 watts. My amp is total max is 400amps, 4x100. So it should be fine. if it starts to blow ill probably just go buy a aftermarket speakers in the newspaper or something like that.
Quick Reply: Car Deck
