Cargo Light Wiring Question
Hi guys, I'm brand-new to this forum, and to Chevy's in general so be kind
Here's my question: Where are the wires which feed the cargo lights in the rear of the cab (above the bed) located? I'm asking because my truck has a Snug Top shell on it and I'm thinking about disconnecting the factory cargo lights and using the wires for them to power the interior light in my shell, that way I could turn it off or on with cargo light switch on the dash.
Thanks in advance
--Kevin
Here's my question: Where are the wires which feed the cargo lights in the rear of the cab (above the bed) located? I'm asking because my truck has a Snug Top shell on it and I'm thinking about disconnecting the factory cargo lights and using the wires for them to power the interior light in my shell, that way I could turn it off or on with cargo light switch on the dash.Thanks in advance
--Kevin
[&:] I'd remove the cargo light housing unit, find the hot wire and connect to it. Run that wire through the cargo ligt unit itself throgh a small drilled hole, seal with silicone. Run the wire into the shell to the light hook it up and ground the light. Make sure you attach to the cargo light wire not the brake light wire. Good luck
Thanks! It's hard to belive it's been a year and I *still* haven't gotten around to doing this! After I posted that I had the same idea but just haven't done it yet. Thanks for the reply!
--Kevin
--Kevin
RazzMaTazz
Apr 27, 2015 9:47 PM
jlmnjem
Jun 30, 2010 1:13 AM
Brucgraham
Apr 14, 2010 6:18 PM
Mille Racer 69
Mar 15, 2010 8:08 PM
cargo, chevy, classic, diagram, disconnect, lamp, light, shell, silverado, silveradocargo, snugtop, switch, switchwiring, turn, wiring
